Correct Routing For Ace Clutch Cable
OK so I usually run it be Haines the left headlight bracket, between the down tubes and direct to the clutch cover. Is this correct, or is there a more original specs for routing locations? Thanks in advance!!! :ugeek: Victor
Re: Correct Routing For Ace Clutch Cable
As I remember it routes under the tank on the right side by the mounting bolt. Many people that restore have it wrong and the position of the shift lever also. ------------------Clarence
Thanks Clarence! :ugeek: Victor
Workinman
Post by Workinman »
taber hodaka wrote: Wed Apr 01, 2020 4:31 pm As I remember it routes under the tank on the right side by the mounting bolt. Many people that restore have it wrong and the position of the shift lever also. ------------------Clarence
I realize this is a very old post, but I’m wondering about the “position of the shift lever” mentioned here. I’m just finishing up my Super Combat and want to make sure everything is correct. I did route the clutch cable directly under the front gas tank mounting bolt on the right side.
Thanks for any help!
Chris
Super Combat
In line with the bottom of the shift cover.
Users browsing this forum: No registered users and 25 guests
