Victors Combat Wombat Thread!
Re: Victors Combat Wombat Thread!
So, I was a busy beaver today! All that’s left to do is assemble the shifter back in the side cover! That gets done tomorrow. I’m tired. Victor
It took me a while to find the bag in which I put the shifter parts. Shifter assembly complete now. All greased and ready to mount. I’ll put the shift lever on after mounting chain & cover.
BTW, do you guys just hook up a grease gun & fill the shifter case thru the grease zurk? :ugeek: Victor
Well I mounted the magneto/shifter cover anyway. Even though I’ll have to remove it to mount the chain and set the points. But here’s the motor assembled from the left side! :ugeek: Victor
Looking good victor. You could use some electrical shrink wrap on the wires going to the coil.------Clarence
I was looking for a better front fender mount that I knew I had, but naturally, I couldn’t find it when I was mounting the front fender.
So I found it cleaning up last night, and buffed & polished it today. It is WORTH the effort to change it out! :ugeek: Victor
Old Original Mount
Old Original Mount
Polished replacement
Here’s the 2 side by side. You can really see the difference! :ugeek: Victor
All changed out!!! Happy 4th everyone!!! :ugeek: Victor
back at you victor, your doing a great job....albert
If you are going to use the old enduro rider "trick" of fully packing the shifter mechanism from the bottom to just below the control shaft - I recommend an artists palette knife and fingers.
Actually I used something almost the same. Finger & a large flat blade screw driver and just packed it all around! Of course I put grease on everything as I assembled it as well! :ugeek: Victor
OK. I reversed the foot peg assembly so it’s on correctly & mounted the motor in place. Also put new shrink wrap on the ignition wires! :ugeek: Victor
Motor in!
Motor in!
Air box mounted. I decided to leave some of her battle scars showing. After all, she is 46 years old! :ugeek: Victor
Got the air boot on. Didn’t have any more 3” pinch clamps so I just used a 3” hose clamp for now. Ready to mount the exhaust! :ugeek: Victor
Just need to pick up the seat from the upholstery shop tomorrow!!! Oh and mount the chain, and put oil in the tranny, and pre-mix in the tank!!! :ugeek: Victor
The project is looking good Victor! Maxie
Thanks Maxie! How’s 2 the Max coming along? :ugeek: Victor
Got the seat back! Now I just need for Terry to fill my order for rubber parts. Brake, shift & kick rubber & the fender mud flaps! :ugeek:
Couple more! :D Victor
you got something there all right, nice job, better keep that one in the house....albert
So, the one part I still need is the rear number plate bracket. Anyone have a used one they can part with?
I seen them at Hodaka Days you should have been there. Are roads go clear to New Mexico. -----Clarence
Larry S
Post by Larry S »
Vic
You need one more exhaust spring. It goes from the front setting bracket( part # 959169 ) down to the pipe.
Larry S
The cables clutch and throttle cables are not routed correctly, which can cause cable damage. -----Clarence
Larry, all 4 exhaust springs are mounted. I even cleaned & repainted the springs with high heat engine paint. :ugeek: Victor
Clarence. How are the clutch & throttle cables supposed to be routed? Since I received the bike without them on the bike, I have no reference. :ugeek: Victor
