Spark arrester
Spark arrester
What can you use for a spark arrester for the Bad rock ride? Here in Utah I have raced desert with just a wire screen hose clamped over the end of the pipe for the arrester....will this work for the Bad rock ride? The wire screen is like the one used in a screen door. DG
- RichardMott
Re: Spark arrester
What muffler do you have on your bike? Is it a stack muffler or a racing aftermarket?
Re: Spark arrester
I have a circle F pipe on it.
- RichardMott
Re: Spark arrester
I Googled Circle F pipes and the site shows several models. None for a Hodaka. Which model has been adapted to your bike. If you can reference this pipe, perhaps Circle F has an arrester for it. Or at least one you can find. I saw several on eBay.
Re: Spark arrester
There is a Circle F Hodaka model and I bought mine from Paul last year.
Re: Spark arrester
They look for the forestry stamping on it as well as the screwdriver test.
Re: Spark arrester
Here's the pipe. Thanks Rich that is what I needed to know was do you need the stamp. Now where can I find one? DG
Re: Spark arrester
FMF Universal is the easiest to find. They run $150 roughly and you need to know if you need 1 1/8" ID or 1 1/4" ID inlet.
Re: Spark arrester
I think I've found a sparky that will work.....Thanks DG
Re: Spark arrester
Hey DG, I have the same pipe. What did you end up with on the spark arrestor? Mine requires ear plugs for competition. Did it help that problem?
Re: Spark arrester
Max....I found a supertrap that will slid on the end but wont have it till next week. DG
Re: Spark arrester
Cool! Keep me posted if you would.---Thanks!
Re: Spark arrester
Nice picture of your Hodaka.
What engine do you have in it?
Re: Spark arrester
It is a 94 bottom end with a 03 cylinder and a radial head that RK Tek did for me. pipe is a circle F and a PWK 28mm carb.
Re: Spark arrester
Max I also found this spark arrestor on ebay for a rm80 and it was a bolt on.
Re: Spark arrester
Hey Doug, thanks for posting the pictures and info! I need to do something like that on my circle F pipe to make it forest legal. Be sure to take ear protection on your epic journey. We don't want you coming back "hearing impaired" like us old racers. Enjoy tour trip!
PS---I forgot to say the bike looks great!
Re: Spark arrester
Max...this bike is my wife's bike that I'm just finishing so she can ride the poker run at this years hodaka days.
Re: Spark arrester
Wow, another nice machine, I wish I could be there but too many irons in the fire this year. Do have fun!
Re: Spark arrester
I would be interested to know what carb you used, what jets you ended up with and what you had to do to the carb to breather boot to get it to fit. I am setting up a CW with a reed and thinking of switching to the spigot mount carb.
Re: Spark arrester
Bill...I think I got the manifold for it off eBay and the boot is the stock 95 cut back about 1/2 inch. One thing that I need to do is get some studs for the manifold.
